#11 |
Liked 167 Times in 81 Posts
In theory maybe but there's plenty of metal to metal contact at the gasket area.
Tim Schmackpfeffer 762 SS |
#12 | |
Liked 278 Times in 110 Posts
Since spark plugs operate at a very high voltage 40K volts or more?...but very low current something measured in miliamps . A very small contact area with the head should be enough grounding....In theory...would like to hear more on this ...these plugs have a tapered seat and no washer to compress. When the seat hits the head...thats it..they dont really turn after that. I dont see how they can be over tightened without causing severe damage. So im going to theorize (again) that the plugs were so hard to get out because they have been in there awhile, and no anti-seize was used. |
#13 | |
Liked 708 Times in 285 Posts
#14 |
Liked 806 Times in 246 Posts
After ripping the threads out of my alum head from a seized spark plug, I'm not inclined to put in a plug without anti-seize again. Incidentally, happened at a divisional race 1000 miles from home so not the most opportune time for it to happen.
Jim Caughlin SS6019 |
#15 |
Liked 534 Times in 143 Posts
#16 |
#17 |
Liked 73 Times in 36 Posts
Biggest problem with anti-seize is that folks tend to slop it on instead of using small amounts per the mfg's instructions.
![]() Regards, HB2 ![]() Dissident |
#18 |
I use anti-seize, however, not all anti-seize products are the same. I recommend either a Copper or Nickle based high temperature antiseize. The Champion brand that Curtis Reed showed in the earlier post is a very great product used in aviation.
Based on recommendations from a friend that managed a NASCAR engine shop for many years, I use Copaslip high temp anti-sieze on the spark plug threads. Copaslip makes two products, Copaslip and Molyslip; the one to use is Copaslip without moly. Moly, when exposed to high temperatures may induce corrosion. Another great product is Jet-Lube NIKAL anti-seize, which is nickel based and the Ford XL-2 High Temperature Nickel Anti-Seize. Not only I recommend these products for spark plugs, but also with O2 sensors. Also, proper torque is critical, for the right thread engagement I suggest using the manufacturer specification. I have seen to many plugs that appear to have been installed with a breaker bar. It is also recommended that when you have a sealing washer, torque, loosen and re-torque to compress the washer, making sure you get the proper thread engagement and heat transfer. |
#19 |
Liked 240 Times in 112 Posts
With dissimilar metals (steel spark plug, aluminium head) there's an electrolysis that occurs. That is what welds the plugs into the heads like in Jims example. Electricians use it for the same reason. The same electrolysis that occurs in the cooling system and can be measured with a volt meter because its acting like a battery. And where an anode saves other things in the cooling system from erosion.
Dave Noll, EF/S ,?/SA 6526 |
#20 |
I also use it on intake & header bolts. Anything that screws into aluminum.
Ed Wright 4156 SS/JA |
