Liked 586 Times in 162 Posts
Is it legal to remove them and any tips on how to on a 1973 Nova?
TIA Already gave up. Last edited by rboyle; 10-15-2020 at 10:07 AM. |
#2 | |
Liked 5,129 Times in 1,956 Posts
However , seeing there's no tech, it's not enforced anymore. PM me and I'll tell you how I would do it on a '73 Nova bracket car ;-)
Liked 2 Times in 2 Posts
Not legal but on our '87 Grand Prix bracket car, I chopped off both ends at the welds with a cutoff wheel, (After cutting out most of the inner door panel to make room). It wasn't easy but damn, they sure are HEAVY!
dev0 |
Liked 654 Times in 196 Posts
Mine were easy because we made sheet metal door panels, as Devo said you will be amazed how much they way. My Nova was a bracket car and weighed 2520 minus driver with sbc aluminum heads.
Liked 317 Times in 62 Posts
I would never take the crash bar out of the driver's door.
Bob Shaw V/SA 515 |
Liked 166 Times in 71 Posts
Is that not part of what the side bar of the roll bar/cage is supposed to do? Yes I realize not required in slower cars, but it is recommended!
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
We race a couple slow class cars (N/SA up)
They all have NHRA legal rollbars and 5 pt. Harness. You can be running 100 MPH and get hit by a 150 - 160 MPH Factory car thru the top end! When a fast car was 125 - 130 MPH = I did not worry like I do now!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 10-16-2020 at 02:28 PM. |
Liked 100 Times in 20 Posts
Not safety related but a 70 Cuda SS/DA car I owned had fiberglass crash bars installed to look like the originals. Pretty creative car with some factory help back in the 70's.
Liked 284 Times in 87 Posts
I've done it several times over the years (before plasma cutters). It takes 2 people, one that is good with a torch and a good helper. Fill a large cooler with ice and water, soak a large heavy bath towel in the cooler, wet the inside of the door. Fold and place the cold soaked towel on the outside of the door skin in the area of the cut, quickly cut from the top down with a torch. If it doesn't completely cut on the first attempt, move to the other door. DO NOT COOL THE WARM PANEL IF FIRST ATTEMPT FAILS, the door may shrink and distort panel. Be patient and restart procedure once the door cools naturally. Try this on a junk door first to see how things work, if you can. The object is to keep the door skin COLD while cutting. I have done this on several finished cars to help trim some weight, to compensate for the owners "Second Cheeseburger Syndrome". Hope this Successful Method helps...MB.
