#1 | |
Liked 735 Times in 386 Posts
Robin. Thanks. No matter what fluid is used you can tell if all injectors in a set will flow the same or not. But I am not sure how much the fluid used effects the flow rate so that injectors can be compared to injectors from another source. Stan |
Liked 269 Times in 99 Posts
Liked 99 Times in 21 Posts
You never know what you are getting. I bought remanufactured injectors for a 2.3 Ranger I was rebuilding. It was a POS truck and gonna be used as a farm truck, trash truck, and local beater. It never ran well. I took some original Motorcraft injectors from a 3.0 in my brothers junk yard and the truck seemed to run better. I'm sure every exprience is different. There are you tube vids showing hoe to use a 9volt battery, wiring harness, and injector cleaner to refurb your injectors.Don Jackson
