Old 12-06-2020, 01:38 PM   #11
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: LOST 10mph AND ABOUT 6 TENTHS
Originally Posted by Bill Marshall View Post
If the engine ran good on the dyno , then what parts are different between the car and the dyno ? Usually the dyno has it's own ignition box and it's own fuel system . Maybe check these two systems out to start with .
We took the coil and ignition box out of the car and ran it on the Dyno made good
power[/QUOTE]
So the only part that remained in the car and was not tested on the dyno was the fuel system . Not sure what type of pump or regulator you have , but the entire fuel system is in question including the fuel cell and any filters . Also check that the fuel cell has an open vent so the cell doesn't get a vacuum in it while the pump is running .
