Old 01-01-2021, 01:19 PM   #17
FED 387
Liked 333 Times in 180 Posts
Default Re: LOST 10mph AND ABOUT 6 TENTHS
Try disconnecting the fuel line at the rear of the car blow it out with a low pressure air hose ---if you have a filter blow the line between rear of car and front of filter make sure its open ---then try from tank to before the filter with line disconnected--- from the rear to front try blowing from tank side of the filter thru the filter --- probably a clogged filter --if you do the 3 step method you will isolate where its "plugged"--- how old are the fuel lines in the car?? are they Aeroquip??? or stock??? if they are more than 2-3 years old might be time to replace them as the lining has maybe deteriorated -also check regulator for any obstructions ----FED 387
