Old 02-01-2021, 01:11 PM   #1
curtis reed
Liked 125 Times in 59 Posts
Default Re: Canton accusump vs. Moroso accumulator
Originally Posted by Dano View Post
Without a Pressure valve, how does your system know when it needs oil?
I put 7lbs of air pressure on the back side of it. When started the engine fills the accumulator with oil to the running pressure. When I get on the brakes at the end and the pressure drops the accumulator pushes oil in to cover the loss until the engine catches back up. Just a constant give and take. Being just a bracket racer I am on the brakes really hard sometimes at the stripe and it covers no problem.
curtis reed is offline   Reply With Quote
Old 02-01-2021, 01:26 PM   #2
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
......at 7 lbs, how much oil in accumulator?
SC 707Y
Dano is offline   Reply With Quote
Old 02-01-2021, 02:11 PM   #3
curtis reed
It's the 3qt version but really only holds about 2 1/4-2 1/2 quarts typical. It will depend on engine oil pressure also. My on track pressure was about 48-50 hot. When I put the car in the trailer I always bring the rpm up so I get the pressure up to about what it sees on the track because at idle I only have about 20-25lbs depending on how hot the oil is. I want a good amount to prelube when I start up next time. When I have changed oil and checked that's about what I have seen as far as volume in the accumulator.
Old 02-01-2021, 03:59 PM   #4
Dallas Kelly
Liked 85 Times in 21 Posts
I run a Moroso 3qt however I pre-charge it to 25psi. I can tell you that filled with 80psi engine oil pressure it only holds a measured 52oz of engine oil. You have to decide how low you want your engine oil pressure to fall by the time the accumulator is empty, whatever the triggering event.
Dallas Kelly is offline   Reply With Quote
Old 02-01-2021, 08:35 PM   #5
Chevy55
Banned
Liked 179 Times in 89 Posts
Originally Posted by Dallas Kelly View Post
I run a Moroso 3qt however I pre-charge it to 25psi. I can tell you that filled with 80psi engine oil pressure it only holds a measured 52oz of engine oil. You have to decide how low you want your engine oil pressure to fall by the time the accumulator is empty whatever the triggering event.
The accumulator doesn't start filling till the engine until engine oil pressure overcomes the preset pressure in the accumulator.
Chevy55 is offline   Reply With Quote
Old 02-02-2021, 07:25 AM   #6
Dano
Dano's Avatar
So.....without a regulated pressure switch, when you turn engine off, doesn't the pressurized oil in accumulator pump back to the oil pan? If so, no pre-oiling at start up, (how important this is, is debatable) would happen as the accumulator is empty.
SC 707Y
Old 02-02-2021, 07:35 AM   #7
Darcy Clarke
Liked 530 Times in 36 Posts
Without a switch or manual valve the oil pressure will bleed off. Not having a switch to me is a waste of time as it defeats the purpose.
Darcy Clarke
A/SA SS/EA
Darcy Clarke is offline   Reply With Quote
Old 02-02-2021, 10:30 AM   #8
Nmbr1GMfan
I think the pre-lube feature is a secondary feature to the accumulator. I would guess most are utilizing it's capabilities as a safeguard against oil starvation.
Todd Greene
Old 02-02-2021, 11:35 AM   #9
curtis reed
I run the electric valve on mine but I don't run the pressure switch.
Old 02-02-2021, 12:01 PM   #10
mishsc
Thank you all for your comments and opinions. Your help is much appreciated.
mishsc is offline   Reply With Quote
