Old 04-22-2021, 10:13 PM   #6
littlemanjoe
Liked 75 Times in 28 Posts
Default Re: O2 sensors
Originally Posted by Darcy Clarke View Post
As a guy that runs 3 multi-carburated cars I have found both on the dyno and on the track to truly tune you need one in each primary. The collector O2 work but is an average of 4 cylinders and you can still.be way off. If you do run 8 make sure you have lots of battery reserve!!
Darcy Clarke
6254
SS/EA A/SA
Darcy, The car is running a 16 volt system with alternator. Is battery reserve still a concern?
littlemanjoe is offline   Reply With Quote
