Old 05-06-2021, 01:27 PM   #1
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: I need hearing aids which kind?
If you are a Vet. go to the VA no cost and they do the testing first, free replacement repair and free batteries for life.
Bob Pagano A/SA
Old 05-06-2021, 01:35 PM   #2
Tinker Toy 2
Don,
I'm like you never protected my hearing while being around racing from a similar time period and heavy construction equipment.
Make sure what you have is not Tinnitus. Paid for audiologist to set me up with rechargeable bluetooth expensive set about 2 years ago only to find out that hearing aids will not completely do away with Tinnitus even adding " white noise" to the adjustment.
Good luck,
Tinker Toy 2 is offline   Reply With Quote
Old 05-06-2021, 01:59 PM   #3
FED 387
Liked 333 Times in 180 Posts
If you are a VET go to the VA for testing BEFORE you do anything ---You are going to need a complete hearing test to evaluate what you can and cannot hear--Test usually takes a long hour or so and done in a sound proof room. Different words, types of voices (children) foreign accents etc. it all figures into what your hearing loss is the remaining hearing range that you have. They also will set the aids up so that the volume is correct for each ear and if you turn them up or down they will be synchronized. When it come time to make a selection get the type that has the molded to your ears part that goes into the ear and has a very thin wire that goes to the device behind the ear and over the top of your ear . Blue tooth is nice also the TV listening mode option is good but those batteries only last for about 1/2 the time if you use that option I have a OTICON from the VA . Also not sure if they still make them but my older aids had small plastic tubes that went from the earpiece to the part behind the ear. They get brittle and either crack or break over time (like every 6-9 months)and you have to replace them--- About $30 at the hearing aid centers. Batteries last about 3-7 days on average 7 if you turn the aids off over night. Use the TV mode of listening maybe a day or 2 at most. I take the battery out of the 6 pack card and let it sit for about 5 minutes as they "air activate" themselves otherwise they only last for a short period of time then install them into the aid. I have had mine for years and the first time I tried them it was a whole new world out there as to what I could hear---same comparison of sorta like putting on glasses or taking them off ---clear or blurry---good ones are not cheap----you get what you pay for!!!!!----- FED 387---
Old 05-06-2021, 02:08 PM   #4
Billy Nees
Liked 7,793 Times in 1,746 Posts
Hey Don, do ya know what you get "hearing aids" from? Listening to too many A-holes!
Billy Nees 1188 STK, SS
Old 05-06-2021, 02:40 PM   #5
Frank Castros
Liked 2,740 Times in 967 Posts
I suffer from pronounced hearing loss and also Tinnitus. How do hearing aids affect those with Tinnitus, if at all?
I'm a Costco member and have put off getting hearing aids for too long and it's now having a great effect on my daily functionality.
Old 05-06-2021, 02:59 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Frank. I have Tinnitus The hearing aids really have no effect on my tinnitus. They might make it less noticeable when wearing the hearing aids. When you have Tinnitus you are never alone. You will be amazed what you are missing when you finally get hearing aids. The first thing you will think is the world is a really noisy place. Hearing loss creeps up on you slowly so you don't notice until its too late. They are not perfect and it takes a bit to get used to them. I had to turn the volume down on mine at first a it is overwhelming. The kept increasing the volume as I got used to them. You need a really good audiologist to work with you to get the frequencies right for you. Get the Bluetooth type with an app that works on your smart phone to be able to adjust the volume and modes. Don't wait it does not get any better.
Mike Pearson 2485 SS
Old 05-06-2021, 03:21 PM   #7
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
I've had the latest bluetooth , rechargeable model from Costco for about a month. Of the three brands I've used over the years they are tjhe best ANDleast expensive.
Old 05-06-2021, 05:17 PM   #8
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
to be clear and possibly correct a couple of assumptions in here-the Costco hearing aid center is staffed by licensed audiologists, with the latest state of the art equipment to determine where your issues are and to help dial in your new units. it is NOT go in the store, take something off the shelf, see if it works. I used a private audiologist the first time, when I went back a year later they were no longer in business. I received the same level of testing and far better support from Costco and they were 1/3 of the private "franchised" company.
Old 05-07-2021, 08:19 AM   #9
Mike Pearson
Do you know what brand the hearing aids you bought at Costco are? for the price they would be good for a spare pair in case of a problem with the ones I wear all of the time. Might just give them a try. Do they have an app for an I phone?
