Old 05-29-2021, 11:31 AM   #1
Jeff Kempton
Jeff Kempton's Avatar
Liked 67 Times in 31 Posts
Default Re: 1955 Chevrolet front end alignment problem
Tri-Five Chevys are known for this. I solved it by using these on my '57, they are OEM-style repros with extra caster built in.
https://www.classicchevy.com/chevy-u...-344513-1.html
Jeff Kempton is offline   Reply With Quote
Old 05-30-2021, 07:07 PM   #2
Lyn Smith
Liked 996 Times in 200 Posts
Thanks Jeff. I did not know about the upper arms with the 5 degrees built in to them. In fact I was in the process of building some with the ball joint moved. I will just get some of these instead. Will let you know how they work.
