#21 |
Liked 204 Times in 54 Posts
I never had one. Then I got one. Now I'll never not have one.
Not only does it help you understand where to pick up, it shows you when you're running into trouble. Oil temperature comes to mind. Same with oil, fuel and transmission pressure. People will spend $1500 on a weather station and not even think to buy a basic racepak. It makes no sense. If I had to choose between one or the other, without a second thought I'd choose the racepak. |
#22 |
Liked 275 Times in 76 Posts
Dean,
When I built my car for Stock, I purchased a Computech DataMaxx, it is a built up system and still in the car. Originally it was engine and clutch monitoring. Oil press, water temp, O2 in both collectors, input shaft, driveshaft, accel. I mainly monitored what the clutch was doing, and that is all it does now since switching to SS and EFI. The EFI now logs the engine vitals. I will say this as someone else pointed out. I discovered why I was having oiling issues with the EFI combo by the data logs. Seeing oil press fluctuating as the engine accelerated and would recover. Adding an additional quart of oil and the problem went away. Its an investment, and more info to validate what you think just happened on a pass, if everything is healthy, or setup as efficient as possible. If someone is not into looking at data it is not a worthwhile investment. Sean
#23 | |
Liked 455 Times in 147 Posts
If there was a lot of fast cars in ones class, yes it then should be very helpfully. I know guys that have 6-7K invested in the F, G and H stockers data systems. 25K in Comp cars! Some of the " Dime Rocket" cars that can run 1.30-1.40 plus under, I would think investing in a Data recorder is unnecessary and not cost effective. So I see it as fewer the cars in your class and slower the class, Data recorders become a fun tool but are not going to provide a return on your investment to win rounds. Just my view. Steve Teeter STK/SS 620 |
#24 | |
Liked 80 Times in 19 Posts
Very interesting point. Obviously I have a slower class car and trying to weigh were the money is best invested as I am on a budget. I know I will never have a 1.00 under car but I'm shooting for .4 - .5 under.
#25 |
Liked 497 Times in 243 Posts
If you run a clutch, I'd consider it a must have.
JMO |
#26 |
So question for everyone that got a data logger. How much ET did you pick up from the data logger alone from identify the optimal configuration?
#27 |
Liked 704 Times in 281 Posts
Mine is in a bracket look alike super stocker. It should me converter to tight. Motor going rich on top end. Played around and gained a solid .12
#28 |
Liked 734 Times in 385 Posts
How about we ask a different question. How many feel that the data supplied from runs and about changes saved you both a nice amount of both time and money?
Stan |
#29 |
Liked 19 Times in 11 Posts
i have a racepak sportsman with a o2 you don"t know what your missing without one great tool wouldn't be without one
#30 |
Liked 348 Times in 79 Posts
The rpm DL10 seems to be the most cost effective for those on a budget. Can the 2 o2 package be added to the DL10?
