#91 |
Liked 225 Times in 136 Posts
f
The baro you are showing is corrected to sea level. You should be using station pressure that is the actual baro reading at track temperature = 60.86 deg f relative humidity = 98 % uncorrected barometer* = 29.24 inHg corrected barometer* = 30.20 inHg wind speed = 1.96 mph wind direction* = NW (333°) more info: current metric | historical | forecast | help dew point = 60 deg f saturation pressure = 0.538 inHg vapor pressure = 0.527 inHg grains = 79.9 air density (w/o water vapor) = 97% air density (w water vapor) = 96% This really important of you are using weather data for any correction input. |
#92 |
Liked 328 Times in 80 Posts
Potts-Hall vs TC Morris Stock
Nick Morris vs Ricky Decker SS |
#93 |
Liked 797 Times in 165 Posts
I believe the winners were TC Morris and Ricky Decker , congrats to all
Dave Casey 1330 STK |
#94 | |
Liked 734 Times in 385 Posts
Ralph, I am confused (that happens a lot these days). If the 29.71 BP Larry posted is corrected BP and you show corrected BP as 30.20. Why are they different? I was thinking maybe corrected BP - Vapor Pressure but that does not workout. Stan |
#95 |
Liked 1,021 Times in 218 Posts
Congrats! Top notch racers!
Brett Candies 4192 Stock/SS God Bless America |
#96 |
My info was taken from the website airdensity.com it is a very good website as you sill see if you go to it it has most tracks on it and if they don’t have one you want just call them and they add it. I have used them to verify info when I was on the IRL team. We had one of the Mercury barometers. When we got to a race track I would call nearest Airport for the actual station pressure to get their reading. I would suspect that Larry’s baro was set up to something other than actual baro reading at his nearest airport. I was sure when I seen his baro reading this morning it was off. I raced and tested at National Trail many times and have never seen a station pressure that high National Trail actual altitude is over 900+ feet. We used to care a altimeter instead of a cheap baro. If you at the track set it to zero feet and look at reading for the actual station pressure right where the Altimeter is. That was the way I did it when I was Dragracing. When I was at Ford in early 60s we had the Mercury Baros at the Test Tracks and at the Dyno building. As far as the website I listed. I have e never asked them where they get their data and who’s all that data entry but I’m going to call and ask tomorrow.
QUOTE=Stan Weiss;643743]Ralph, I am confused (that happens a lot these days). If the 29.71 BP Larry posted is corrected BP and you show corrected BP as 30.20. Why are they different? I was thinking maybe corrected BP - Vapor Pressure but that does not workout. Stan[/QUOTE] |
#97 | |
OK what I did was ► 30.2 - .527 = 29.673 What I see now is that Larry's temperature and RH% are not the same as yours. If I calculate what his VP is ► 30.2 - 0.4935 = 29.7065 Stan |
#98 |
What's up with Divisional Live Timing today, dare I ask?
#99 |
Liked 1,604 Times in 583 Posts
#100 | |
Liked 119 Times in 40 Posts
