Old 10-31-2021, 04:24 PM   #1
SSDiv6
Default Re: Performance Gain Stock Rockers to 1.5RR?
Many years ago, due to the pushrod tip going through the stamped rocker arm pushrod seat, I took a set of Oldsmobile rocker arms, laser welded a piece of 4130 Chrome Moly steel that had been cut and shaped to the contour of the rocker arm pushrod seat, and then had them solution heat treated. It was a matter of longevity than performance; the modified rocker arms were heavier than the OEM replacements by a lot.
The owner of the car approached Danny Gracia at a race, showed him the damaged rocker arms and what he was planning to use in lieu of the OEM replacement rocker arms. Of course, Danny immediately said they would be illegal and he could not use them. Then, some time later, Clark Holroyd comes up with the same concept and design for Chevy and Pontiac engines and were deemed legal to use by Danny.
It appears to be the case of who you are and who you know.
Old 10-31-2021, 07:46 PM   #2
Frank Castros
Liked 2,765 Times in 978 Posts
Any cam duration, any valve spring, adjustable push rods, adjustable rockers , roller rockers and now solid lifters. The evolution of what we have today.
Old 10-31-2021, 09:18 PM   #3
GTX JOHN
Liked 2,493 Times in 700 Posts
I had noticed that a couple times about Danny = More often years ago
I "think" he actually likes me now after 30 years.
I would have never got away with modifying the cast rockers.
We broke plenty of them on Mopars and a few on my Big Block Chev.
John Irving
741 Stock
741 Super Stock
Old 11-01-2021, 08:58 AM   #4
SSDiv6
John,
I modified the rocker arms only to address a weakness on the OEM stamped rocker arms after the allowance of higher pressure springs and lifting the duration and overlap specs on the camshafts. They were not installed.
We asked permission to use them and were rejected.
My issue with Danny was the fact that later on, he approved the same exact modification from Clark Holroyd for BBC and Pontiacs.
No matter how it is addressed, Danny was always controversial in many of his decisions throughout the years.
Old 11-04-2021, 02:20 AM   #5
GTX JOHN
i would like to elaborate with some stories = but I
better not!
John Irving
741 Stock
741 Super Stock
