Liked 2,354 Times in 554 Posts
You are missing the point of this thread. This ties directly to the AHFS.
Daren Poole-Adams NHRA Stock/SS 2007 |
Liked 1,583 Times in 582 Posts
Many years ago, NHRA was looking at the wiring of the Idle Stop on Quadrajet carburetors. It appears some racers found a way to use it as a throttle limiter by using a toggle switch.
As I stated earlier, racers are creative and there are many ways to skin a cat. (Sorry Cat Lovers... ![]() |
#3 | |
Liked 1,104 Times in 302 Posts
#4 | |
Liked 271 Times in 107 Posts
I knew a racer years ago that had one of these on a stocker,but I think he was using it for a staging device. Flip a switch and it holds the throttle open for you. |
#5 | |
Liked 2,336 Times in 464 Posts
#6 | |
In this particular case, the guy had it rigged to limit the throttle opening and got caught. It was directly hooked to the throttle lever with a modified bracket. NHRA Tech made him remove it and took it away. |
Liked 4 Times in 4 Posts
Most of us understand that you are on a mission to un-ring the bell on the changes to the AHFS. The point you are missing is that the AHFS is of no concern to more than 80% of the racers because they never will trip the review triggers. And most of us understand that you are simply trying to recruit us to do your bidding to enhance your racing program. NHRA understands that as well. I'm sure they have read your posts about admonishing fellow Camaros racers for going too fast. You brought this on yourself. The changes will likely stay in place to the AHFS - which, by the way, is the same AHFS as we have raced under for 20 years. Stop whining and race your cars.
#8 | |
