Old 03-10-2022, 04:58 PM   #11
Jim Grande
Liked 18 Times in 9 Posts
Default Re: Air Induction
I have run my Super Stock 69 Camaro with cowl scoop open and closed.
No difference!
Jim Grande is offline   Reply With Quote
Old 03-11-2022, 09:21 AM   #12
stock1080
Liked 94 Times in 38 Posts
I have tried it in a 82 z/28 hood with the flaps,,, no gain,,, I would't waste your money, just saying
stock1080 is online now   Reply With Quote
Old 03-11-2022, 12:15 PM   #13
Randy Wells
Liked 1,144 Times in 354 Posts
I found one pretty cheap, I will restore it and try it, if it doesn't work I will sell it, they are hard to find.
Randy Wells
I/S 5628
Randy Wells is offline   Reply With Quote
Old 03-12-2022, 10:56 PM   #14
Don Anderson
Liked 25 Times in 9 Posts
Talking Re: Air Induction
NOT a hood scoop, but cold air cleaner housing to fender tubes to the front on a Fox Body car. Fresh air instead of hot air under the hood. It was worthy in this part of the country in August.
Don Anderson is offline   Reply With Quote
Old 03-13-2022, 12:09 PM   #15
Rory McNeil
Don, my 85 5.0 carbed Mustang also had the ducting from behind the bumper to the inner fenders, but I tried back to back testing with the factory dual snorkle air cleaner with the plastic flex tubes connecting the fender ducts to the air cleaner snorkles, with and without a K&N filter inside, and basically it ran the same with or without the air cleaner housing on, or just letting the ducts blow the air all around the engine compartment. Maybe that huge aluminum air cleaner assembly trapped enough engine heat between the intake manifold and carb, to offset any benefit of potentially cooler air going into that "oven".
NHRA 6390 STK
M/S 85 Mustang
Old 03-13-2022, 10:08 PM   #16
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
I've done the same with my 85..no difference
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 03-14-2022, 02:56 PM   #17
Don Anderson
Well Rory mine runs just a little harder than your stuff in worse air in D-5 compared to the west or east coast. 3500-4500` air conditions here in July & August. Just have to keep trying stuff. I know a SS car that put his cold air on and picked the car up. What you should see is in the 330 times........
Old 03-14-2022, 05:36 PM   #18
Randy Wells
Its ugly but if it works for a couple hun I can live with it. I did remove the snorkel.
Randy Wells
I/S 5628
Name:	Cowl Induction 1200 X 1000.jpg
Old 03-20-2022, 09:32 PM   #19
Randy Wells
I did some testing today at Heartland Park Topeka, not a good day to test but did get my clutch dialed in. A steady head wind 19MPH gusting to 26. fastest run 11.746 @ 112.54 made 6 runs, slowest 11.82 @110.85, last run of the day with the air induction air cleaner 11.772 @ 111.98 with 22 MPH head wind, and there was no starting line prep, bunch of street cars tracking water to the line all day. May have to try the cowl induction again Thursday in Noble Ok.
Randy Wells
I/S 5628
Name:	Heartland Park 3-20-22-2.jpg
