Liked 133 Times in 76 Posts
Where is the fluid level on the stick after making a pass? Do you have a temperature gauge on the trans? My T350 would puke some out if the fluid level was a little high when the trans was hot. When I say hot my pan temp was usually around 150*. When fluid level was correct it would still have a mist so I put a catch can on the vent with a clear hose. Never had much in the hose but the mist even when on the transbrake and double entered with pan at 200*.
