Old 11-16-2022, 02:09 PM   #21
SBillinson
Liked 183 Times in 48 Posts
Default Re: Block Honing
"in order to accurately “map” a cylinder bore in order to obtain a clear dimensional picture of how that bore is shaped from top to bottom, a special “PAT” gauge is used."
https://www.championbrands.com/wp-co...2010_42-48.pdf
SS/BS 1921
SBillinson is offline   Reply With Quote
Old 11-16-2022, 04:03 PM   #22
Liked 10,838 Times in 2,253 Posts
Thanks for sharing
Old 11-16-2022, 07:33 PM   #23
Liked 1,899 Times in 427 Posts
My thoughts differ slightly from a lot of folks. I will check an aftermarket block just as closely as I will an OEM block. The best surprise is no surprise.
I do not disagree with my friend the tall man.
What I should have said was that the new aftermarket stuff is usually, good enough that you can simply check for perpendicularity, and then your dimensions will quickly show if there's an error. Every dimension on the aftermarket block will almost certainly required being "kissed" or "dusted". Same with any other aftermarket component, save a camshaft, I know of few people than can do any "adjustment" required on a camshaft, even if they can find an error.
Old 11-16-2022, 07:40 PM   #24
Originally Posted by dragracerray View Post
Alan what is a PAT gage?
Ray
Ray,
The original "PAT" gauge that I speak of was developed by Traco Engineering, a couple of decades back, when they were working with GM in the development of the LS based engine racing program. GM required assistance because they could not get the LS engines to "seal up" and stay sealed up. It turns out that the bores on the LS engines of the time were never truly round. Even in the production engines, when no problem was present. It "appeared" that they were round. On machines, and with gauges, they "measured" round. Well, it turns out a regular "Sunnen style" dial bore gauge doesn't actually measure roundness with any real accuracy. So the "PAT" gauge was developed. The new CNC hones followed shortly thereafter.
Old 11-17-2022, 09:14 AM   #25
Ralph A Powell
Liked 225 Times in 136 Posts
How did we ever get by back in the day? Yesterday I dug out my my OLD BILL JENKINS SA DESIGN BOOK in the block section Jenkins shows how he hand hones an small block and what stones he uses. Don’t know how we ever got by?
Old 11-17-2022, 03:00 PM   #26
I had a pretty close relationship with Jere Stahl the last few years he was around, and as a result, a connection with Bill Jenkins (as in, Jere would tell me that he and Bill were talking about one of my engine programs, and a direction I went with my R&D, and "Bill said to tell you that he thought you were smarter than that" and laugh.) where he would pass along things that he thought that I should look at.
Bill sent me a message one night telling me that we should be using a new Sunnen CNC hone, and we should have individual diamond mandrels for each 0.010" in bore size. That was what they were doing with their engine programs.
Yeah, we've come a long way since he once told me to plumb two Holley blue GPH 110 pumps in series, with 10 gauge wiring, and 0.060" washers under each pressure relief spring in the pumps, because our C/MP popped in high gear. Fixed it, too.
Bill, much like WJ, was absolutely as hilarious as he was brilliant, once you go to know him. But he never hesitated to bust my chops if I screwed up. It was always funny to get "Bill's take on Alan's mistake" from Jere.
Old 11-17-2022, 07:14 PM   #27
Ralph A Powell
I first met Stahl in early 62 when he had a Lenoard gas station in Romulus, Mi on the intersection of Northline rd and West Huron River Dr. He mounted my first set of Cassler slicks in the early fall of 62. It was at his station that I met Jenkins in the spring of 63 Jenkins had brought the 63 Z-11 for Jere to build him a set of equal length headers.
