Old 01-15-2023, 06:51 AM   #1
tolaas
Default 16 V Battery
Hello, Which agm 16 volt battery do you prefer?
XS power batteries or TurboStart, or something else?
Thank`s Torbjorn Laas Sweden
tolaas is offline   Reply With Quote
Old 01-15-2023, 10:51 PM   #2
SDT1DYI
Liked 456 Times in 148 Posts
Default Re: 16 V Battery
XS battery's. But what ever AGM 16 V you buy MAKESURE its packaged correctly so it will arrive with no damage. I have had several damaged in shipping especially the 76 lb group 27 ones. They are heavy!
Good luck,
Steve Teeter Stk/SS 620
SDT1DYI is online now   Reply With Quote
Old 01-17-2023, 08:08 PM   #3
Jim Caughlin
Liked 805 Times in 245 Posts
I have an old pair of 16V Turbo starts that are at least 10 years old and work perfectly. In my other car, I have a pair of Turbo starts that both died in about one year. Based on that, I am thinking that something has gone wrong with Turbo Start's manufacturing process. I have switched over to XS, no problems so far.
Jim Caughlin is offline   Reply With Quote
Old 01-17-2023, 10:44 PM   #4
Liked 1,857 Times in 420 Posts
I've got one of the 16 volt chargers that went down, and no one can work on the expensive boat anchor, you can't buy parts for it, either.
I'd rather have a good 12 volt AGM or lithium battery.
Old 01-18-2023, 12:16 AM   #5
Randy Wells
Liked 1,144 Times in 354 Posts
For a fuel injected car with all the sensors maybe, but a waste of money in my book.
Randy Wells is offline   Reply With Quote
Old 01-18-2023, 12:00 PM   #6
Eman
Liked 133 Times in 76 Posts
Asisde from spinning the starter faster what is the reasoning/purpose for using a 16v on a car with minimal electrical useage? Is it for powering the ignition when not charging with an alternator?
Old 01-18-2023, 01:00 PM   #7
Race Clean
Liked 129 Times in 53 Posts
For a Stocker with working alternator (as per the rules ) I would not bother with it but for a Super Stocker without alternator I could see it useful .
I found that lithium 12V battery's spin engines pretty good
Stop global whining
Race Clean is offline   Reply With Quote
Old 01-18-2023, 01:41 PM   #8
pmrphil
Liked 348 Times in 152 Posts
Spins the water pump and the fan faster, too
Phil Molski
PMR Performance
S/C 1623
Old 01-18-2023, 09:14 PM   #9
Woodfin
Liked 288 Times in 109 Posts
I now have several years of experience with 16-volt systems. I do not see any advantage to the 16-volt battery, and I have returned to a 12 volt with alternator. I now think that overall, the 12 volt has the most advantages.
Old 01-18-2023, 09:15 PM   #10
mnmaxwedge
Liked 172 Times in 53 Posts
I put one in my stocker last year. Fuel pump works better, with the fan and water pump running I can cool my car in about half the time that I used to, maybe less than that.
mnmaxwedge is offline   Reply With Quote
