Liked 81 Times in 45 Posts
Iam building the 352 Cobra Jet and what is the opinion of using motor plates in this application. Pros and cons.
Thanks Kirk |
#2 | |
Use the centered front plate, not the offset plate. Racecraft and ATF make a plate for either using the OEM timing cover or Jesel Belt. They also make a plate if using the 1994-1995 timing cover, which it is different than the earlier engines. https://www.racecraft.com/motorplates-c-284/ https://www.atfspeed.com/14-Inch-Thick_c_365.html |
Liked 362 Times in 81 Posts
Theres no cons. You support the engine front and back which takes alot of stress off the block. Ties the front together. And with the motor mounts removed, it increases header clearance. Taking the engine in and out is easier too. You can mount things on the plate like a coil or whatever have you.
Pat Clemente #1427 B/S |
Do they make a special starter for proper engagement to the flex plate or am i over thinking this? I would need spacers for the torque converter spacing which is no problem and i would need to recheck the driveshaft for fitment also. Anything else?
Thanks Kirk |
#5 | |
Liked 314 Times in 177 Posts
Good idea. The engine already has a 1/16 block plate so just leave it out and add a 1/8 plate to it.
Thanks |
Liked 1,032 Times in 283 Posts
1/8" is too thick in my opinion, my Comp Engineering mid plate is the same thickness as my factory block plate. It came with a spacer to bolt behind the flex plate to.bring the trans/flexplate and started back to the original alignment. I'm gonna say its no thicker than .062.
Duane Hoven 1342 SS/GT |
Liked 5,155 Times in 1,968 Posts
"Snouts" (hubs) on converters are changed routinely, but "long" converters are usually built by adding a button to the pilot and using spacers on the mounting tabs. This way they can be brought back to OEM stack height more easily ;-)
Liked 183 Times in 48 Posts
I agree with SSDiv6 about using a center motor plate.
I use one that's offset and it's going to be changed. Too bad I put a new rear end housing in the car with MW axles three years ago for the offset engine. Apart other benefits, centering the engine provides more room for headers. You may have to offset/relocate the steering column if the shaft connecting to the rack gets in the way of exhaust ports. You can use spacers on the column mounts to move things up or down. You may want to fabricate or buy a tube-style column. That'll reduce some weight and allow you to mount it to suit your needs.
SS/BS 1921 |
#10 | |
SS/BS 1921 |
