Old 03-07-2023, 06:27 PM   #1
Coleydog
Liked 53 Times in 38 Posts
Default Re: Best Brakes for Mopar B Body Stocker?
Are you worried about rolling or stopping? Most all the tracks I’ve been to have very ample room to stop, almost could coast to the turn off. Of course drums aren’t as pretty as disc brakes.
Old 03-08-2023, 07:44 AM   #2
Liked 10,783 Times in 2,242 Posts
If you are using drum brakes on the rear check the backing plate for stretched holes. It won’t make it roll any easier but it will make safe to race. The backing plate allows the shoes to hold the car on the starting line.
Old 03-08-2023, 09:04 AM   #3
darrellbargeron
It stops and holds fine now. I'm just looking at what could be done to find some et. I would like to be more competitive with those newer corvettes around here if that's possible.
darrellbargeron is offline   Reply With Quote
Old 03-08-2023, 05:28 PM   #4
Coleydog
Spend your money on ceramic bearings anywhere you can put them
Old 03-09-2023, 10:11 AM   #5
All of the Corvette’s are top shelf but one had a difficult time keeping it within the rules. Go figure.
Old 03-10-2023, 04:21 PM   #6
Frank Castros
Liked 2,740 Times in 967 Posts
Before the rule changed to allow aftermarket disc brakes we reinforced the backing plates, also because we used six cylinder 9" drum brakes at all four corners we coasted to the last turn off whenever we could. Excessive braking at the finish line was not my favorite manner of racing for obvious reasons. If I had my choice today I'd buy brakes from Lamb Components. Safety is priceless.
