Liked 900 Times in 191 Posts
I have a 92 Mustang, 302 FI C4 (reverse valve body w/air shifter) in SS. Had trans rebuilt over the winter. Ever since, transbrake isn't working correctly. Voltage was checked, solenoid works, transfluid pressure was checked. First run of the day everything works fine but on subsequent runs, transbrake doesn't hold and I go through the lights. Happened yesterday again at LVD. Anyone ever have this happen? Valve body issue? Thanks for replies.
Bob Don 128 SS Last edited by Bob Don; 08-01-2023 at 08:16 AM. |
Liked 1,877 Times in 577 Posts
I had a hipster solenoid roll pin, started backing out, and sometimes it would catch not engage, engage or get stuck. Not sure if your trans brake even has a roll pin in the solenoid but definitely something to check.
Liked 2,471 Times in 696 Posts
In my SS car I had a similia issue.
Turned out that I had a leg strength issue. I am 75. I had to lower the pressure switch a lot to compensate.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 08-01-2023 at 09:31 PM. |
#4 | |
Liked 859 Times in 234 Posts
Whose valve body, internal or external trans brake selenoid and does the trans work fine when not using the trans brake? Can you hold it with the foot brake?
Liked 561 Times in 138 Posts
Also make sure your air bottle has enough C02, might have enough pressure in the bottle first time out but loses air pressure? Maybe an air leak? Consider switching to an electric shift instead of air shift, I did and much happier.
Tim Stickles
Tim Stickles |
Liked 642 Times in 192 Posts
Liked 133 Times in 76 Posts
Go through the lights, I'm guessing you go forward when on the TB. Does it hold at all or does it roll forward as soon as you take your foot off of the brake? I'd check the wiring first to make sure the hot solenoid isn't showing a fault in the wiring. 2 wire solenoid? Where is it grounded?
