Liked 880 Times in 311 Posts
MH or Industrial blocks have a water hole for spark plug cooling passages that are in the MH or industrial heads. They are easy to spot.
If you find a block try to get one that has the Dash end number(-1) closer to one or zero. The higher the dash number the more mold/casting modifications. Closer to zero or 1 is usually a block that has been cast matching the original prints. A -1 could be a lot better core than a block with a -15 on it. Sonic testing is important
Adger Smith (Former SS) Last edited by Adger Smith; 10-01-2023 at 11:55 PM. Reason: add |
