Old 01-05-2024, 11:52 AM   #1
J.R. Haddad
Liked 1,469 Times in 308 Posts
Default Accusump - pros & cons
I'm thinking of installing an accusump on my LS motor. When I do things
like this, I always find out why I shouldn't have done it, after I've done
it. Would like some real world opinions from people with experience
in dealing with accusump type of installations.
Thanks,
J.R.
J.R. Haddad is online now   Reply With Quote
Old 01-05-2024, 12:42 PM   #2
Steve Grady
Steve Grady's Avatar
Liked 124 Times in 42 Posts
Default Re: Accusump - pros & cons
Pros
Keeps oil pressure from dropping when stopping after burnouts & braking at the end of the run.
Allows to run a Lower oil level in pan if desired.
Allows prelubing the engine prior to start.
Can be operated mechanically
Can be operated electrically, Both on-off and/or Engine oil pressure reading.
Cons
Additional weight of canister, oil & plumbing.
Space to mount canister and route plumbing
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is online now   Reply With Quote
Old 01-05-2024, 01:15 PM   #3
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
everything Steve said-I saved a Buick 455 block when they started getting scarce and had kinda wide main clearances (for a street car) with an Accusump-prelubed on startup when the key went to on, street/stripped that thing for years like that
Old 01-05-2024, 01:27 PM   #4
Mike Mans
Liked 299 Times in 48 Posts
We run accumulators on both of our cars, and have the electric solenoid connected to the ignition switch on them both as well. The only con is the small amount of additional weight, but I think the pros greatly out-weigh that. With this setup, we always turn on the ignition switch and let the motors prime until the oil pressure falls back to 5-10psi before we fire the cars up each morning. And of course the motor gets a full prime everytime you go to start it up so it's just a great insurance for every bearing and lubed surface. Highly recommend these to anyone, it's a great investment!
Mike Mans is offline   Reply With Quote
Old 01-05-2024, 02:58 PM   #5
J.R. Haddad
Thanks Guys. I really appreciate the feedback. Mike, as always I owe
you another one. Pretty soon you'll be able to right me off on your
taxes!!
Thanks Again,
J.R.
Old 01-05-2024, 07:10 PM   #6
JGrossijr
JGrossijr's Avatar
Liked 460 Times in 59 Posts
I like having an accumulator and recommend using the Canton EPS smart valve regardless of who's accumulator you choose
JGrossijr is offline   Reply With Quote
Old 01-05-2024, 10:28 PM   #7
Jason Shepard
Jason Shepard's Avatar
Liked 114 Times in 29 Posts
How much additional oil do you need to run? 2 qts?
Jason Shepard is offline   Reply With Quote
Old 01-05-2024, 11:06 PM   #8
J.R. Haddad
Jason, I would like to have 1 to 1 1/2 quarts available.
Thanks,
J.R.
Old 01-06-2024, 07:39 AM   #9
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
J.R.
\why, what issue do you have that you are trying to bandaid?
Old 01-06-2024, 10:06 AM   #10
Steve Grady
Thanks,
J.R.
Moroso has them available in 1.5 Quart and 3 Quart.
