Old 01-09-2024, 02:44 PM   #11
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: Accusump - pros & cons
Originally Posted by 1320racer View Post
There is, it doesn’t fix the root cause of low oil pressure which is due poor oil control. Hence it’s a band aid and should call into question one’s choice of engine builders IF said low oil pressure on deceleration and/or braking is a real concern.
That said, you and anyone else that choses to do so, need not justify your decision about your program to anyone and can “foolishly” spend your $ on and installing an accusump and it affects no one here but this thread isn’t about you and isn’t about an engine that turns 10,400rpm either!
Last, I have yet to have any professional engine builder tell me, suggest to me, that I need to use an accusump with their engine,
Maybe you should have Mr. Reher build you an engine…….
