Old 04-11-2024, 07:38 PM   #6
GTX JOHN
Liked 2,506 Times in 701 Posts
Default Re: Wanted: Set of usable pistons for mopar 318
I did some checking and the 68 to early 70s pistons have
4 VALVE notches similar to 72/73 340 engines.
You need to use them rather than flat tops or you will have
nearly zero valve clearance with a stocker camshaft with
correct lift.
Sorry I did not know the early engines had a different piston.
John Irving
741 Stock
741 Super Stock
