Liked 48 Times in 16 Posts
Now what? Everyone but Stanfield cars DQ'd? ClusterF_ _ _! Really trying to love this class but 4 cars does not make a good race
MADISON, Ill. - Final order after 2 rounds of qualifying in Factory X at the NHRA Mission Foods Drag Racing Series, 13th annual NHRA Midwest Nationals: Psn---Num-Driver, Home Town, Car Type---------------Qual-ET--Qual-Spd-Top Spd 1 439 Stephen Bell, Shevreport LA, '23 Mustang 7.129 193.32 193.32 2 441 Greg Stanfield, Bossier City LA, '24 Camaro 7.142 189.55 189.55 3 445 Aaron Stanfield, Bossier City LA, '24 Camaro 7.166 190.43 190.43 4 290 Rick Hord, Orlando FL, '24 Camaro 7.335 187.36 187.36 ------------ Not Qualified ------------ 5 313 Jesse Alexandra, West Bend WI, '24 Camaro DQ 6 L177 Lenny Lottig, Meyersdale PA, '24 Camaro DQ |
Ladder so the DQ's are official. #Joke
https://www.dragracecentral.com/DRCS...er=30#indextop MADISON, Ill. - Eliminations ladder in Factory X at the NHRA Mission Foods Drag Racing Series, 13th annual NHRA Midwest Nationals: Psn--Car-#-Driver------------ET----------------------------------------- 1 439 S Bell 7.129 ________ |________ 4 290 R Hord 7.335 ________| | |________ 2 441 G Stanfield 7.142 ________ | |________| 3 445 A Stanfield 7.166 ________| |
Liked 3,227 Times in 981 Posts
Since I have a NHRA.TV subscription I?ve always watched Stock, Super Stock, Comp regularly and have watched Factory Stock and Factory X some but will no longer, what a farce.
Liked 348 Times in 152 Posts
What in creation did they DQ Lenny Lottig for?
NOT having anything illegal???
Phil Molski PMR Performance S/C 1623 |
Liked 148 Times in 34 Posts
Our lower intake pans which have always passed previous eye and hand measurement inspections, failed the 3D scanner test for having too smooth of radius compared to there as cast intake. Our inspection was done after Q1 so we were unable to make any changes and told DQ for event. Of the 6 FX cars that were there I guess we won the lottery draw as we were the only two who torn down after the run. Hopefully the 3D scanner is going to be used more often as it will clearly make the lines go from gray to black and white. I had no argument other than see you at the next race.
FX L177, FSS L177 STK L177 Lenny Lottig MMPS 77 |
#6 | |
Liked 226 Times in 97 Posts
Tony Leonard S/ST 56 S/C 53 |
#7 | |
If it was, then NHRA would have allowed either a change, or just run it that way ![]()
#8 | |
Liked 6 Times in 5 Posts
..you should be a laywer...or maybe you are.............. |
