#11 |
Liked 759 Times in 379 Posts
I ran Total Power’s small 12volt battery which is an aircraft battery made by Concorde and its junk as longevity is concerned.
#12 |
Every car that I've raced for the last 30+ years (except the FWD stuff) has had a Deka 850/1000 CCA battery. They're made in Pa. they last a long time and they'll start almost anything. I can live with the weight penalty.
#13 |
Before switching to 16volts in 2022, I ran AC Delco batteries in my door cars for 30 years, same spec as Billy’s Deka and I never had a bad one, failure or missed round due to a slow cranking or dead battery.
The fact is the small, lightweight 12volt batteries just do not have the cranking amps that the full size batteries do nor do the last as long. Last edited by 1320racer; 10-10-2024 at 02:57 PM. |
#14 |
Liked 293 Times in 65 Posts
I've been running the 11 lb Braille batteries for about 10 years now and they've been great. I do have two, one in stock location and one in the trunk. Not sure I'd trust just one at only 360 cranking amps, but they have a 21 pounder with 550.
I've left the fan and water pump on for a couple hours (twice in one weekend lol) dragging them down to 20-30% and they charge right back up. The ones in the car now are from 2020 so I'll replace over the winter. |
#15 | |
Liked 502 Times in 130 Posts
Eric Merryfield 1883 STK |
#16 |
Liked 706 Times in 283 Posts
In my bracket car I ran 1 optima and 1 motorcycle battery (11lb) with alternator. Didn't know if it would work. 2 seasons later motorcycle battery gave up.
But be a stocker is the correct size battery need to be in stock location? |
#17 |
Liked 974 Times in 310 Posts
Iv'e been running a single 11 lb. Braille 12v lithium with an alternator for years. No issues .
#18 |
Liked 170 Times in 56 Posts
I've been using 2 of the Odyssey batteries with no issues. They are 2 years old now. Keep a maintainer on them and only charge at low amps. Not crazy about lithium ion batteries.
Tom Flowers E/SA 3860 |
#19 |
Liked 49 Times in 22 Posts
My XS battery works great, use it in two different cars, and never put a battery charger on all weekend of racing. weight is about 23lbs
Steven Barnes Stock 704 N/SA |
#20 |
Liked 205 Times in 44 Posts
