View Poll Results: Agree or Disagree? | |||
Agree |
123 | 96.85% |
Disagree |
4 | 3.15% |
Voters: 127. You may not vote on this poll |
Thread Tools | Display Modes |
#11 | |
Liked 7,908 Times in 1,754 Posts
#12 |
Liked 2,768 Times in 980 Posts
Does a $20 to 25K stipend for16 Technical inspectors at Indy sound reasonable?
#13 |
Liked 463 Times in 60 Posts
Agree with the poll question, but what's the point of being a record holder anymore? With AHFS in place, being a record holder doesn't necessarily indicate you're the fastest in class. There are more than 65 classes in stock and all but 11 are at minimum. There are more than 125 classes in Super Stock (Crazy) and all but 8 are at minimum. In my opinion, the ability to set records isn't as much of a problem as the penalty for going fast. The only way to take advantage of being fast, is to hide how fast a car is until it's needed in a heads-up race, and then only use what you need to get the job done. It's arguably not a whole lot different than throttle stop racing that so many of us abhor.
I think a better conversation would be how do we incentivize displays of performance capability in Stock & Super Stock. Here are my suggestions.
#14 | |
As far as the "how fast a car is until it's needed" thing, I'm pretty sure that we (the Racers) all know who's fast and how fast they can go.
#15 | |
Liked 469 Times in 99 Posts
Agree, but would add that the AHFS needs to be corrected by only adding horsepower when a engine combination has an average in the data base more than 1 second under the index. |
#16 |
Liked 44 Times in 14 Posts
Agree - as long as they make two qualifying passes at the same event with the ETs within 1% of each other. On a representative fastest run of 10.00, that would be a 2nd run no slower than 10.10.
Dave White NHRA Stock/SS 606 |
#17 |
Liked 11,011 Times in 2,263 Posts
I would like to see a record be listed until it is broken.
#18 |
Liked 880 Times in 311 Posts
The 8 records in Super Stock
Record vs Index SS/CA 8.86 10.05 -- 1.21 SS/KA 10.49 11.25 -- .76 SS/BS 8.92 9.65 -- .73 SS/AM 8.00 9.00 -- 1.00 SS/CM 8.88 9.50 -- .62 SS/FM 9.86 10.50 -- .64 GT/QA 10.74 11.75 -- 1.01 SS/TB 8.94 9.90 -- .86 5 of the 8 fall in the AHFS averages 3 are quicker than 1.00 The numbers seem to show that assuming the records will impact the AHFS is assuming alot. Only 3 out of the 8had real impact on the AHFS. These 8 may not be the fastest in each class, but they are the record setters. They put up a number that says "Go faster than this and you will be the record setter" The list of "Things to do" by JRGrossi Jr. are (IMHO) good reccomendations, with the exception of the number of qualified in the field. In this day and age as expenses increase an all run field seems fair to me. "Qualified fields at all national events. Raise the quotas and qualify 32, 64, or 128" seems to be more "Elitist' rather than an incentive.
Adger Smith (Former SS) Last edited by Adger Smith; 10-22-2024 at 08:09 AM. Reason: sp |
#19 |
Liked 4,389 Times in 505 Posts
Looking for info about Captain Jack and another racer who set records this weekend @ Indy. Would like to give them shout out on tonight's podcast 8:30EST. Also want to make sure their info is accurate for the December issue of National Dragster.
#20 |
Liked 401 Times in 49 Posts
I know Brian Oakes set the SS/CA record at Rockingham this weekend
Brian and I where the number one qualifiers this past weekend
Jim Marshall 1967 STK |
