Old 10-31-2024, 09:53 AM   #2
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Cylinder leakage test
Originally Posted by Kirk Morgan View Post
Will a gas ported piston and ring package leak the same as a conventional piston and ring package?
Good morning Kirk and to all,
Are you using a leak down tester to quantify this ? A cylinder pressure transducer would probably be the best choice to be sure. What dynamics that actually happens during combustion and the resulting pressures will be much different then we can simulate with a compressed air leak down tester.
The leak down testers vary for tester to tester, the various temperatures while the test is being done and other factors will lead to variation.
If you use the same leak down tester the same way, might give you a reasonable answer, but it will still vary.
If someone on here has a better solution for testing this, I hope you will chime in here.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
