Old 12-21-2024, 09:55 PM   #1
john billups
Default Re: Q jet power piston spring
Checked for vac leak w/ smoke machine.
As for the pistons. I thinking maybe a little pull over .
Well I'll put it back together as it's a backup and work on it next spring.
thanks all who chimed in.
John B645
john billups is offline   Reply With Quote
Old 12-22-2024, 07:22 AM   #2
Danny Ashley
Liked 110 Times in 29 Posts
PM sent
Danny Ashley is offline   Reply With Quote
Old 12-22-2024, 12:34 PM   #3
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
Put flat edge on top base sitting upside down. Must be good and flat.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 12-23-2024, 09:09 AM   #4
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
Get a drinking straw, cut it down to about 4? long. Place it in the vent stack
at abslight angle to catch the power piston/primary metering rod hanger arms. Note the length sticking up. Now start the engine. It should pull the power piston down and the straw with it. If it goes down and stays down
At ?idle? (yes I understand it won?t idle well on its own but you get the idea) then that?s not your problem.
Have you drilled the holes in the primary blades yet?
Kp
Old 12-23-2024, 09:23 PM   #5
monte385
Liked 27 Times in 19 Posts
Get rid of PP & rods & block the vac. supply, reduce jet size.
monte385 is offline   Reply With Quote
Old 12-23-2024, 11:22 PM   #6
Liked 5,153 Times in 1,967 Posts
Surprised..10 posts before anyone mentioned this.
I didn't think anyone used the primary enrichment circuit anymore ;-)
Old 12-24-2024, 01:30 AM   #7
outlaw
outlaw's Avatar
Liked 132 Times in 52 Posts
I’ve never built any for stock or super stock but several for dirt cars and I never use primary rods.
Terry
outlaw is offline   Reply With Quote
