Re: ATTN Sportsman Council Members and Racers
Several have mentioned going back to real racing and a performance eliminator. Well that would be heads up off the index or record. Sounds fine to me! Lower the index? To hell with the index. As Mr. Beard said its all realative. Until you correctly factor the combinations you won't change a thing. Lower the index 1 second and all you will have is a select bunch of underfactored cars patting each other on the back trying to make themselves feel good because they couldn't make middle of the field in todays events if factors were fairly considered and applied where necessary.
