View Poll Results: Should roller rockers be allowed on all stockers?
Yes 113 53.81%
No 97 46.19%
Voters: 210. You may not vote on this poll
Old 06-02-2008, 01:02 PM   #28
SSDiv6
Default Re: Roller Rockers in Stock
Originally Posted by Jeff Lee View Post
Well SSDiv6, you may have access to scientific instruments and labs, but I knew from the get-go when I took a Speed-Pro/TRW AMC rocker and "thunked" it with my fingernail and it went "dunk" and the OEM rocker went "diiiinggg" , then surely the factory offering was better . Although that did lead to a rockwell hardness test which confirmed a huge difference as I suspected...
The lab test allowed me to see the variation on materials and try to find the solution. Yes, you can do it the "Redneck" way via the resonance test, however, I was trying to find how much variation between manufacturers, its ductility and malleability. What I also found with the replacement stamped rocker arms is that in addition to the cycles and loading they are exposed to, the heat affects the malleability.
