Liked 225 Times in 88 Posts
The only thing I learned from a friend who runs a Ford SB is you need a really good pin for the cam timing gear .
Liked 401 Times in 154 Posts
It needs to be a GOOD quality bolt, torqued correctly. Most of the good cams already have a larger (7/16) bolt requirement.
The dowel does not keep the gear from moving, clamp force does.
Phil Molski PMR Performance S/C 1623 |
Liked 61 Times in 25 Posts
I?ve got a new Jesel belt drive sitting on the shelf from a past project. Should be fine😁
