Old 07-28-2025, 12:46 PM   #1
JCChildress
JCChildress's Avatar
Liked 11 Times in 5 Posts
Default Stocker Tooled Steel Cam & Lifters
When using a tooled steel camshaft in a stocker, is everyone using coated lifters or is that just an option ? Is anyone using uncoated tooled steel lifters is what I'm asking I suppose ?
JCChildress is offline   Reply With Quote
Old 07-28-2025, 06:46 PM   #2
Default Re: Stocker Tooled Steel Cam & Lifters
Assuming everything else is good, you can run tool steel lifters on an 8620 steel cam billet. I don't like DLC coatings, at all. I've seen other having good results from the stuff Rocketman does.
Old 07-28-2025, 10:03 PM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Why not the dlc lifters?
Old 07-28-2025, 10:17 PM   #4
WAY too many issues with various DLC coatings in the past. Compatibility issues with oils, other materials it interfaces with, etc. When it starts to come off, and it will, it's like a hand full of industrial diamonds circulating in your engine.
Old 07-30-2025, 04:23 PM   #5
65signet
Liked 49 Times in 22 Posts
I use non coated tool steel lifters with a cast core cam for years.
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
Old 08-02-2025, 04:38 PM   #6
SDT1DYI
Liked 455 Times in 147 Posts
A lot of variables here .
Ramp design, valve weight, spring pressure, Rpm, to name a few.
Cast iron cams with aggressive " Stocker" Ramps , tool steel lifters with 215/400 maybe 100 runs before there's lobe issues and need to be replaced.
More spring pressure , fewer runs, less spring pressure more runs.
Tool steel cam cores, DCL lifters , can run higher spring pressures , no break in issues.
PPPC in NC make a very good DCL lifter
Coating work done in France. Delivery sometimes can be longer than you want. Around 1,250.00 a set.
Steve Teeter Stk/SS. Q620/7888
SDT1DYI is offline   Reply With Quote
Old 08-02-2025, 07:40 PM   #7
Yep. Sold a few dozen sets. The trick for many engine builders was to break in the camshaft using Shubeck lifters, then put tool steel lifters in.There's another brief break in required there, but once the Shubeck lifters burnish the cast iron cam, the tool steel lifters will break in and run reliably, with good quality oil.
You cannot, under any circumstances, run DLC coated lifters on cast iron core camshafts. I know one lifter supplier told people you can, and it was disastrous. Cast iron is by nature abrasive, and DLC simply will not live on it.
Old 08-03-2025, 07:44 PM   #8
JCChildress
I worked in an engine shop that did lots and lots of Late Model Stock engines ( all solid flat tappet ) . We used all cast iron cores and tooled steel lifters. We always broke in engines without the inner springs and used break in oil. I don't remember hardly ever seeing any issues.Our lifters were not coated at all.
I'm just wondering how the tooled steel cam would do with non coated tooled steel lifters. I won't likely own a set of Shubeck lifters. I had an engine builder put a set of Shubeck lifters in a 340 once and we never made a pass. The ceramic came off and it literally destroyed the cylinder walls and pistons. It was around 2000 I think....so 25 years ago.
Old 08-07-2025, 09:28 PM   #9
SS/AM
Steel core cams and DLC lifters went over 1000 miles in NASCAR 20 years ago, all the while lofting the lifters/valves (added lift, big advantage in a stocker).
Lifter foot crown height, and who applies the DLC to them are key, as well as who you talk to at your cam company, in our case it was Steve Brown at Comp, if he's still there I'd call him.
SS/AM is offline   Reply With Quote
Old 08-08-2025, 03:13 AM   #10
john ancona
john ancona's Avatar
Liked 186 Times in 57 Posts
The question is at what lift ,spring rate along with what spring seat pressure
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
