Old 08-14-2025, 07:53 PM   #1
Cuda340
Liked 87 Times in 20 Posts
Default Stock Legal Mopar 340
1968-71 hi-comp 340 +.040, 4.082 bore,Production block,CP pistons, total seal 1.2 mm rings,offset ground steel crank,Manley rods,clevite bearings,Brad Van Lant 🍒 heads,cam & tool steel coated lifters,ARP bolts,T&D rockers,ATI Dampner,moroso water pump,1970 & 1971 intake (both done by Don Little) Steve Wann AVS carb.,MSD dist.original 1971 metering Rod Thermo Quad carb. by Al Etter Ken?s father,it went 11.14 -.085 under in G/SA at Bakersfield in the heat(100 + degrees) on 10/24 in Bracket mode,this is carb.,dist., to pan,all less than 20 runs..$16 K. ,if you want just as AVS 1968-70 combo or 1971 TQ combo $15,500 call or message ?Chad 7147669535. Wanted to add another note it was also 65 lbs. heavy at that time,hopped up in good air possibly -1.10 under
Cuda340 is offline   Reply With Quote
