Liked 323 Times in 46 Posts
Can anyone out there tell me how much HP would be gained by indexing an after market crankshaft from a reputable company?
I understand that indexing a crankshaft is to assure that each and every journal on a V8 engine is exactly 90 degrees apart. Would this not be tantamount to attempting to build a Formula 1 engine to run Stock Eliminator? Sarge |
Liked 7,922 Times in 1,758 Posts
If I needed to get a crank done from scratch, I would probably have it stroked and indexed. Otherwise, I wouldn't bother. Not for a (relatively) low HP and low RPM engine.
Liked 1,032 Times in 283 Posts
Take what your engine makes in hp and divide it by cubic inches, now figure out the displacement increase and plug the hp per cube into the new formula. That should give you a start. It may increase more due to the compression increase also. Thats what was explained to me many years ago by an old time.class racer.
Duane Hoven 1342 SS/GT |
Liked 14 Times in 9 Posts
stock crank yes, could be up to .005 off, high quality aftermarket most likely no increase
#5 | |
Liked 1,952 Times in 439 Posts
Yes, INDEXING assures each rod journal is at 90 degrees (assuming we're discussing a V8). If I bought even a relatively expensive aftermarket crank and the journals were not correctly indexed, I'd be annoyed, and return it. If you're talking about STROKE, then, no, if I had not paid for the extra 0.014", I would not bother with it. When you correct an OE crank, you should go for proper index first, since that relates to camshaft and ignition timing.Since you usually have to grind it to get the correct index and correct journal size, then you also go for the stroke. You often cannot approach the full 0.014" allowed while getting the index correct and maintaining decent journal size (I don't like going too small on an OE crank). Hope that helps. One or two crank manufacturers will make you a new crank with the 0.014" built in. Be prepared to pay through the nose, and wait until you retire before getting it.
Alan Roehrich 212A G/S |
Liked 24 Times in 9 Posts
Stroking a crank for a stock or super stock is worth nothing, you're induction limited, so increasing cubic inches is pissing in the wind. Narrowing the bearings is worth something.
#7 | |
Liked 735 Times in 386 Posts
While that maybe true at peak RPM. I can see even a small increase in both displacement and CR having an impact through out the curve. Stan |
Liked 11,030 Times in 2,266 Posts
As my friend George would say "if it can not hurt it helps"
The crank grinder needs to have fresh or newly rebuilt indexable chucks with positive stops. Make sure the correct radius is used and fully demagnetized before insulation. |
#9 | |
Yeah, and your friend George is fast enough to make most of us look like we're sitting still.
Read again, ALL stock and super stock combos are induction limited, your gains are theoretical and do not exist in the real world.
