Old 06-09-2008, 09:28 PM   #1
rustbucket79
Exclamation SBC stamped steel rocker ones, what brand?
I can't find any of the Crane Nitro Carb rockers (1.5 ratio, 3/8 stud) as my suppliers are sold out. What are some of the other brands you guys use, similar application. (1.260" single spring)
GM, Comp, Isky, Lunati, ????
rustbucket79 is offline   Reply With Quote
Old 06-09-2008, 10:12 PM   #2
Bub Whitaker
Default Re: SBC stamped steel rocker ones, what brand?
GM the older the better...yup that's correct... old origional 60's 70's 80's...they don't make them that good anymore. the newer rail rockers from GM are ok also and since they have changed the guide plate / pushrod rule you can now legaly open the pushrod guide hole so it won't interfere with the rail rocker. Make sure they are GM as they should be black in color ( phosphorous coated )
Bub Whitaker is offline   Reply With Quote
Old 06-09-2008, 11:31 PM   #3
SSDiv6
Liked 1,604 Times in 583 Posts
The Nitro Carb rockers are also available from Elgin. Have you checekd inventory with Competition Products?
http://www.competitionproducts.com/p...s.asp?dept=474
Old 06-13-2008, 07:37 AM   #4
dean ribeiro
Liked 238 Times in 78 Posts
just got a set of Crane Nitro rockers through Scoggin Dickey in Texas (last week). Thye had Crane drop ship directly to me overnight. Thye were very helpful and showed up on time!
dean ribeiro is online now   Reply With Quote
Old 06-14-2008, 02:04 AM   #5
rustbucket79
Thanks guys, I ground/polished a nice radius on a set of Melling long slot's that we had in stock for a few years for the customer to try. (we had been using them years ago prior to the Nitro Carbs) He's going to pull them after his next race for me to magnaflux.
The next step is is to dig through our inventory of stock GM rockers and do the required clearancing mods.
I have heard that Crane was having some supply issues but hopefully it will be resolved quickly for the suppliers I use.
