Old 08-20-2008, 03:09 PM   #1
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: Doug Linke GT/MA. DQ'D ?
[QUOTE=Travis Miller;79783]The others in teardown were GT/JA Michael Volkman, SS/AM Paul Ricci, SS/AM Jeff Tripp, SS/AM Brad Plourd, and SS/BM Jay Higgins. Everyone including the modifieds had to pull a head and all passed.[QUOTE]
Travis...could you explain the reasoning and purpose of pulling a cylinder head in a Modified Class engine?
Old 08-20-2008, 04:02 PM   #2
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
Text removed by Travis Miller
Travis Miller is offline   Reply With Quote
Old 08-20-2008, 05:03 PM   #3
SSDiv6
Originally Posted by Travis Miller View Post
Reasons for pulling a cylinder head of a Modified class engine.
1. To measure the bore and stroke in order to calculate the cubic inch
2. To measure the bore center spacing dimension.
Page 168 (Section 10F - Modified) of the 2008 NHRA rulebook under ENGINE, 4th sentence reads: "OEM bore center spacing mandatory."
There are even Comp classes where OEM bore center spacing applies. Many other classes have a ruling on bore center spacing dimensions including Pro Stock, Funnycar, and Top Fuel. Those dimensions are measured with the cylinder head removed.
Travis
(Disclaimer: Opinions expressed by me on this forum are exactly that, my opinions.)
So...do you guys gave up on pumping the engine for CID measurement? Do not get me wrong, I am not being a critic; I like your new approach. Will there be any enforcement for those using the Aurora block, GM P/N 24502650? (a.k.a. Pro Stock Truck Class block - 8.1" Deck and requires an adapter for its use with a GM pattern bellhousing)
Old 08-20-2008, 10:04 PM   #4
Travis Miller
Default Re: Doug Linke GT/MA DQ'D ?
Old 08-21-2008, 04:57 PM   #5
Jeff Lee
Jeff Lee's Avatar
Geez...hope they wern't too hard on you!
Jeff Lee 7494 D/S '70 AMX
Old 08-21-2008, 05:12 PM   #6
Jack McCarthy
Liked 476 Times in 117 Posts
poor travis...
just trying to do his job... and explain to the CUSTOMERS what and why goes on in tech and SHAZAAM his nuts are in the nutcracker again, and his keyboard belongs to his bosses...
travis (and a few others) really try to do thier job, be fair and follow the rulebook... however he is continually overridden by the powers to be...
i wonder if he will even bother to throw out anyone at indy... he is about 2 for 7 last 2-3 years
jack mccarthy
p.s. wasnt there a thread on here about censorship ???
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 08-21-2008, 05:39 PM   #7
CycloneFE
CycloneFE's Avatar
Liked 2 Times in 2 Posts
I would hate to be the "admin" and have to go to the barn at Indy and Travis be there.
