Liked 335 Times in 182 Posts
Go to the Dexter website they have a total breakdown of every type /rating axle they make. But before you contact them look at your axles if your trailer is newer than 2001 for an ID number. It is located on the right side of the axles about 18 inches in from the backing plate. It should be about 8-9 numbers long. When you get that number you can contact Dexter and they can suggest the correct parts you will need. Comp 387
