Liked 994 Times in 200 Posts
Ive got a 12 bolt missing a cap. Who makes a replacement cap?
Liked 1,879 Times in 422 Posts
Mark Williams makes steel billet caps.
Alan Roehrich 212A G/S |
www.tomsdifferentials.com
Easy self install....used only on the driver side usually. Comes with upgraded fasteners for the passenger cap, driver side must be drilled and tapped for 1/2" fastener, provided.
"Despite the high cost of living, it remains popular." Dave Cook NHRA N375 |
Why doesn't that one require milling like everybody else's?
~Pete 1970 Nova |
Dunno..
![]() It requires "fitting", but nothing more than what can be done with a file. I've had mine for 12 years.
I was just thinking about this again, and I wondered why I've never seen any bearing cap studs?
~Pete 1970 Nova |
Liked 6 Times in 3 Posts
i found if you tap the existing threaded holes deeper with the 2nd of a three tap set (not the starter taper tap and not the bottoming tap) so that the tap end goes flush with the back side of the opening you can still bottom out a set of studs with over an inch of thread holding. even through the studs bottom out i still used blue locktite.
Ian |
