Old 12-20-2008, 08:39 AM   #1
Bryan Gillespie
Banned
Default Re: Help from any FORD racers..
Mill the heads 20 thou.
get the 750 carb. converted to Alch.
Launch @ 4800 rpm
Shift @ 7200
Let er eat!
Bryan Gillespie is offline   Reply With Quote
Old 12-20-2008, 10:06 AM   #2
Rich67stang
Liked 116 Times in 27 Posts
I have a svo351 stroked to 435, I ran in IHRA hotrod. It goes 9.34 @ 141 and 10.90 @ 136. It has blue thunder heads. I ran a c-4 from dynamic converters and shifted on time. I shifted third gear on rpm @ 7200.
I have used every SBF combo and to make them run you need alot of comp. and stroke to get them moving off of the stop. My car weighed 2992#. Glen fergueson runs a 351 stroked with yates heads also and he goes 10.90 @ 134. You also need to spin the crap out of that 306,331,347 to run #'s...I build alot of NMRA motors for guys. Your welcome to take my 435 for 10k TK...I am going SS racing. I would put those heads you have on a 4.00 stroke, 4.125 bore motor with a .721 or so lift cam with .270-.280 duration@ .050., super victor intake, mvh spacer,gary stinnet gas carb. Good luck. I will tell you what DOES NOT WORK ON A FORD. lol
SS/EM 161
Quick Rod 161
Rich67stang is offline   Reply With Quote
Old 12-20-2008, 10:59 AM   #3
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Thanks guys, sounds like I am lacking in compression and cam for now, maybe the gear as well. This car all last year kept having trans issues and only got three or four good runs out of it.
For some reason it never wanted to pull much past 5700 rpm, I thought it may be the hydrolic roller that was in it, never put the mechanical one in it yet.
I am looking at a 408 with aftermarket 4 bolt caps, and a good steel crank. will use my mechanical cam, and heads, have to get a new intake and all.. And switch to the glide with the 5000 stall converter, Do you guys think I need more gear? 3.73's with a 28x10.5 tire?
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 12-20-2008, 11:23 AM   #4
MUSTANG3637
Hey freddie. I run 88 mustang here's what i use to run s/st. 351w 418ci. Afr205 heads, super victor intake, 656 roller cam, 1050 dom carb, 13:1 comp, power glide trans, 5800 stall, 4.10 gear in 8.8 rear end on 10.5 tires. Car weighs 2945 w/driver. Runs 10.0s at 136 and 10.90s at 132-134
jeff d.
MUSTANG3637 is offline   Reply With Quote
Old 12-20-2008, 11:26 AM   #5
Dave Steltz
Dave Steltz's Avatar
Friend of mine runs a Mustang II with a 302....10.30's I think best times, If I remember right 10.90's at about 126...I believe he runs a 800 holley...Lots of rear gear (5.14's) and keep the 3 speed, and lots of convertor (at least 5800-6000 )...little motors need lots of help getting going on the bottom of the track..
You have lots of head and cam, it needs to run up there in the RPM, you should cross the line at 7500 at least...
Just my .02...
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
Old 12-20-2008, 06:16 PM   #6
Freddie
Freddie's Avatar
I have not run the mechanical roller in this car yet. The motor has been running with a Motorsport hydrolic roller one of thier F cams.
