LS-1 C-5 Corvette (Fresh Factory Red Paint)
New Factory Tan Leather Interior Complete Car Built by Mr. Jimmy Parker Solid Axle Conversion (Not a Moser Kit Package) First NHRA legal solid axle C-5 built - July 2010 Run in B,C,D Auto Classes depending on yr claimed & weight (97-03) Car complete less motor & trans Custom fiberglass springs front & rear QA-1 double adjustable shocks front & rear Adjustable track bar Custom fabricated lite weight Stainless Steel Headers by Childress Strange disc brakes front & rear Moser Rear End with lightened ring & pinion, light spool, gun drilled axles Light weight steel drive shaft Mandatory Wheelie Bar New Aluminum Radiator Aluminum Motor Mounts Cross Member & Tunnel - will accept Metric or 350 Trans (Currently Metric) Full Chrome Molly Roll Cage Turbo Action Shifter Auto Meter gauges Magna Flow Fuel Pump/Filter Assembly 5 gal. Aluminum Fuel Cell Big Stuff ECU with data log, double 02 sensor,driveshaft sensor,crank fired Weld Aluminum Star Wheels Hoosier Lite Weight Radials - Mickey Thompson Fronts Car is very light weight with plenty of added weight for class NHRA rated @ 345 HP $45,700 Rolling Paul Boster 614-496-8783 [email]dbosterchc@yahoo.com |
