Old 09-02-2019, 10:25 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1965-70 BBC Hi Performance Factory Parts
1965 396-425HP block IE code casting #3855962 dated E-27-5
1968 ZL1 #3946052 aluminum can am or yenko tall deck 4.40 block dated 06017
1969 3919840 square port heads dated J-30-8 & J-31-8 with all new hardware to build
1970 396-375HP engine CKO code casting #3969854 dated H-20-9 with 3964291 square port heads dated F-6-9 & F-18-9, 6223 steel crank .010 under, 11 to 1 pistons and rods along with factory 8 inch balancer.
1968-69 fuel line for 427 tri power engine new and extra line to bend to fit new
1969 396-325HP and 1970 454-360HP water pump pulley #3932430 DW
PF 25 AC delco oil filter still in the box
AC delco thermostat 195 still in the box
AC delco spark plugs R43 & R44 still in the box newer versions
BBC bypass oil filter spin on
Manley double roller timing chain used for break in only
Can ship if you cannot pick up and can provide pictures. All parts were cleaned and magged and some were pressure tested as well. I am asking $15,000 or best offer for all of the parts or will consider separating them out. Package deal will include free shipping anywhere in the USA. If from Canada can ship their but need to talk and work out the paperwork first.
330-770-2517 Dennis for any questions.
dlv4540 is offline   Reply With Quote
