Old 11-19-2024, 07:43 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default Motown blocks, Bryant and Winberg cranks, Carillo rods, etc
Make reasonable offer for anything. Shipping is available
2 New World Products SB Chevy Motown 2 blocks
# 084010
std. cam
842 lifter bore
3.995 cyl. bore
350 main
nodular main caps
$3300.00 each
TCI SBC/BBC lightweight 29.2 168T flexplate PN 399870LW, like new. Weighs 6.09lbs. Can barely see the contact patch on the starter ring. Original date was 1/19, but was only ran in the car for 2 races. Will need recertified. Excellent condition $300.00
Jesel Dogbone lifters LFD-44002 .842 Diameter set of 16 $600.00
LS Bryant crankshaft 4" stroke 58x - used one season $2600
Carillo rods 6.1 rods (was used with Bryant crankshaft above)
BE :2.2253
PE :0.9285
Length: 6.100
B Width : 0.938
$1000.00
Winberg SBC crank
condition: NEW
stroke: 3.496
main size: 283 chevy 2.300
rod size: 1.850
rod journal width: 1.800
bob wt.:1540
$3500
Oliver I beam 5.7 rods set of 8 - used one season
BE: 2.125
PE: 928
Length: 5.7
Weight each: 575 Grams
$500.00
7" Converter - Dynamic. Powerglide input, flashed 7000 behind 327/275 hp combo. - $500.00
Wilson 4 hole aluminum tapered spacer. Dominator flange PN 024110 - $150 used for test only
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $150 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter used $50.00
JRI 2010-2015 Camaro front struts $350.00 used.
Lingenfelter billet steel LS block girdle, No hardware $500
2 GM truck oil pans (1999-2006) pan only $50.00 each
superstock@live.com for any questions or pictures
shipping available for most all items. Paypal, check, or cash in person
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
