Old 01-11-2014, 05:37 PM   #21
Kegracing
Default Re: Dyno numbers 305
Ring seal is critical. Fixing that will help a lot, and really must happen before you can do much else.
I ran a 87 Firebird 305 carb motor for a while, and they do work well. That was before roller rockers were legal, and I spent a lot of time checking and replacing rocker arms. The 305 was hard on them. The roller rockers should give you some hp and save you a lot of headaches. Use good pushrods too!
Bullet and Comp both work well with stocker racers, and either should be able to get you a good, up to date, cam. I have used both in the past.
Good luck, and have fun!
Ken
Kegracing is offline   Reply With Quote
Old 01-11-2014, 06:24 PM   #22
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Originally Posted by Glenn Hayes View Post
10 years ago, my good friend and customer Jeff Stealy (Rest in Peace my friend) was doing Chevy 305's that were making 415-420 H.P. on the Dyno. And if you ever saw his own Camaro with the 305 in it, it flew!
That was the 85? HO carb. motor,that's what they made.They ran real light, would go high 10's in G. gsa612
Old 01-12-2014, 01:12 PM   #23
philbilly
philbilly's Avatar
i have contacted cp and looks like it may be a couple weeks waitin on some pistons. whoever recommended cp to me i appreciate that.
And yes cp contacted me on sunday. Marshall is top notch.
philbilly is offline   Reply With Quote
Old 01-12-2014, 11:34 PM   #24
69Cobra
Liked 2 Times in 2 Posts
Very Cool!!!
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 01-13-2014, 05:57 PM   #25
nolongerracing
Liked 72 Times in 27 Posts
May have to wait about 6 weeks? That's what I've been told.
nolongerracing is offline   Reply With Quote
Old 01-13-2014, 09:02 PM   #26
Ed Wright
Ed Wright's Avatar
Your gonna like them.
Ed Wright 4156 SS/JA
Old 01-13-2014, 10:05 PM   #27
philbilly
philbilly's Avatar
I was told 4 weeks. But for 200 I can get in 2 weeks. 300 I can have in 1 week. I am doing some negotiating cause I ain't waitin till February for pistons.
Old 01-15-2014, 12:21 AM   #28
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Yes, CP is a good choice.
But if you are not putting them in a properly prepped Bowtie block or a properly prepped/sleeved 350/307 block, you aren't going to find the power you are looking for.
Unless you have a rock solid stable cylinder wall, with the right finish, no piston or ring package will help you.
Also consider calling Total Seal for your ring package. If you are used to buying a $50 ring set, then prepare yourself before you call. Good ring packages can be ten times that amount.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 01-15-2014, 10:34 AM   #29
James Perrone
Liked 1,846 Times in 431 Posts
why CP over everything else? I have them are they that much better than the others?
james perrone 1290 STK
Old 01-15-2014, 12:23 PM   #30
philbilly
philbilly's Avatar
I can tell you what made my mind up. Cp seemed smarter than the other companies. They knew what I was looking for.
