Old 03-15-2015, 10:19 PM   #281
SSGT Mustang
Liked 204 Times in 54 Posts
Default Re: Ford vs Chevy Build-up
Okay, here's the C4 to C5 comparison.
The tops of the valve bodies appear to be the same. The the outside of pumps look the same but have different part numbers (the C5 pumps are supposed to have modifications that most builders perform on C4 pumps). C5 on the right.
The bottoms of the valve bodies are different. The inner-sides of pumps are the same (same part numbers too). C5 on the right.
Housing are almost identical with the exception of better fluid channels in the C5 (on left) and the fine thread band adjusters. I guess I forgot to pull the sprag and shifter linkage when I put the C5 in storage.
The C4 valve bodies fit the C5 case, and vice versa. C4 is the better valve body.
Notice the subtle differences in the valve body passage.
Even the shaft housings are identical.
Drums, gears, etc all look the same.
Hope this is helpful to you or someone else.
SSGT Mustang is offline   Reply With Quote
Old 03-15-2015, 10:51 PM   #282
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
SS/GT ,
Thanks for taking the time to post those C4/C5 trans photos and the detailed differences ...
Proof that a photo is worth a thousand words after all.
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is online now   Reply With Quote
Old 03-15-2015, 11:30 PM   #283
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Here you go Steve -
The C5 was used between 1982 and 1986 at which time it was replaced by the AOD. Casting numbers are E2, E3, E4, E5, and E6 designating the year of manufacture.
Vehicles:
Now, back to those flexplates...whats the difference and which do I need?
Rich Taylor
I/SA - 321
Old 03-16-2015, 12:33 AM   #284
SSGT Mustang
Originally Posted by HandOverFist View Post
I need to purchase a flexplate and have noticed two different configurations for a C4...one with a single step and the other with a dual step. What/why the difference and which do I need?
What brand did you notice a difference?
Depending on the bell housing you use, you need either a 157 tooth flex plate (typically 302) or the 164 tooth (typically 351). You probably need a 157 tooth flywheel, but I would check with dynamic to be sure.
I'll assume that you internally balanced the engine, otherwise you would need to consider two choices of imbalance, 28 oz. or 50 oz. I'm surprised that when you had the engine balanced, the machinist didn't ask for a flex plate.
Regardless, get a decent 157 tooth flex plate (again, depending on bell housing used) and just go with it. You can probably get one from whoever you choose to make your converter.
Old 03-16-2015, 12:52 AM   #285
HandOverFist
Not brand specific as far as I can tell.
Plans have always been on using the 157T bellhousing. I could go either way since they bolt-on/interchange. Matter of fact is the Dynamic will be coming without a bellhousing...I had one donated by a fellow forum member. Btw, the AOD behind the 302 is 164T.
This one is 50 oz. I had the balancer for the machine shop... they simply used a 50 oz flexplate they had in house for balancing.
The difference I'm speaking of is the double center flange vs a single...steps so to speak.
I'll try to post some images of the different plates shortly.
You can easily see the difference between the two. I just don't want to blindly buy one and end up with a useless flexplate lying around the garage...I have enough clutter as it is lol.
Rich Taylor
I/SA - 321
Old 03-16-2015, 01:09 AM   #286
Rory McNeil
Since the OD of a 157 tooth flexplate is about 1" smaller than a 164 tooth, you will also need a block plate for a 157 tooth flexplate as well. On a Ford, the thin steel block plate is sandwiched between the back of the block, and the flexplate, and is needed to properly locate the starter in relationship to the flexplates ring gear teeth.If you were to accidentally use a block plate for a 164 tooth flexplate, the starter would be too far away to allow the teeth to engage.
NHRA 6390 STK
M/S 85 Mustang
Old 03-16-2015, 01:14 AM   #287
HandOverFist
Yes, something else I will need to run down. Ebay would likely be a good place to begin, right?
This plate look correct? http://www.ebay.com/itm/MAVERICK-MUS...42f379&vxp=mtr
Or maybe this? http://www.ebay.com/itm/Ford-289-302...ddd3ca&vxp=mtr
Rich Taylor
I/SA - 321
Old 03-16-2015, 01:18 AM   #288
SSGT Mustang
I hear ya, but you're fine. They are just two different styles. If you look closely, the depth from crank flange to converter flange are the same overall. One just has one step and the other has two. I have used several brands, all with different styles. The JW wheel is just a plate with a thick flange. The depth is the same overall to other brands.
You may want to look at TCI flex plates. They're cheap and SFI approved. You may want to talk to your converter builder first before buying though. They may be able to cut you a deal. If they try to sell you a $300 flex plate for that stocker, then you know you have the wrong builder.
Hope this helps.
Old 03-16-2015, 01:23 AM   #289
SSGT Mustang
This is the guy you need to buy from. Great quality and $30.
http://www.ebay.com/itm/Ford-C4-Auto...item56721d5cd4
Old 03-16-2015, 01:35 AM   #290
HandOverFist
Hope this helps.
ATI is who I was looking to for a convertor. They want $295 for their 157T flexplate. I'm going to call Brian Thompson and get the skinny since he uses ATI in his cars.
Rich Taylor
I/SA - 321
