#281 |
Liked 204 Times in 54 Posts
Okay, here's the C4 to C5 comparison.
The tops of the valve bodies appear to be the same. The the outside of pumps look the same but have different part numbers (the C5 pumps are supposed to have modifications that most builders perform on C4 pumps). C5 on the right. ![]() The bottoms of the valve bodies are different. The inner-sides of pumps are the same (same part numbers too). C5 on the right. ![]() Housing are almost identical with the exception of better fluid channels in the C5 (on left) and the fine thread band adjusters. I guess I forgot to pull the sprag and shifter linkage when I put the C5 in storage. ![]() The C4 valve bodies fit the C5 case, and vice versa. C4 is the better valve body. ![]() Notice the subtle differences in the valve body passage. ![]() Even the shaft housings are identical. ![]() Drums, gears, etc all look the same. ![]() Hope this is helpful to you or someone else. Last edited by SSGT Mustang; 03-15-2015 at 10:28 PM. |
#282 |
Liked 50 Times in 23 Posts
SS/GT ,
Thanks for taking the time to post those C4/C5 trans photos and the detailed differences ... Proof that a photo is worth a thousand words after all.
Steve Stickel 1161 Stk 1167 SS Last edited by Steve Stickel; 03-15-2015 at 10:52 PM. Reason: sp |
#283 |
Liked 33 Times in 16 Posts
Here you go Steve -
The C5 was used between 1982 and 1986 at which time it was replaced by the AOD. Casting numbers are E2, E3, E4, E5, and E6 designating the year of manufacture. Vehicles:
Now, back to those flexplates...whats the difference and which do I need?
Rich Taylor I/SA - 321 Last edited by HandOverFist; 03-15-2015 at 11:40 PM. |
#284 | |
Depending on the bell housing you use, you need either a 157 tooth flex plate (typically 302) or the 164 tooth (typically 351). You probably need a 157 tooth flywheel, but I would check with dynamic to be sure. I'll assume that you internally balanced the engine, otherwise you would need to consider two choices of imbalance, 28 oz. or 50 oz. I'm surprised that when you had the engine balanced, the machinist didn't ask for a flex plate. Regardless, get a decent 157 tooth flex plate (again, depending on bell housing used) and just go with it. You can probably get one from whoever you choose to make your converter. |
#285 | |
![]() ![]() You can easily see the difference between the two. I just don't want to blindly buy one and end up with a useless flexplate lying around the garage...I have enough clutter as it is lol.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 03-16-2015 at 01:06 AM. |
#286 |
Since the OD of a 157 tooth flexplate is about 1" smaller than a 164 tooth, you will also need a block plate for a 157 tooth flexplate as well. On a Ford, the thin steel block plate is sandwiched between the back of the block, and the flexplate, and is needed to properly locate the starter in relationship to the flexplates ring gear teeth.If you were to accidentally use a block plate for a 164 tooth flexplate, the starter would be too far away to allow the teeth to engage.
#287 | |
This plate look correct? http://www.ebay.com/itm/MAVERICK-MUS...42f379&vxp=mtr Or maybe this? http://www.ebay.com/itm/Ford-289-302...ddd3ca&vxp=mtr
Rich Taylor I/SA - 321 Last edited by HandOverFist; 03-16-2015 at 01:28 AM. |
#288 | |
You may want to look at TCI flex plates. They're cheap and SFI approved. You may want to talk to your converter builder first before buying though. They may be able to cut you a deal. If they try to sell you a $300 flex plate for that stocker, then you know you have the wrong builder. Hope this helps. |
#289 | |
http://www.ebay.com/itm/Ford-C4-Auto...item56721d5cd4 |
#290 | |
Rich Taylor I/SA - 321 Last edited by HandOverFist; 03-16-2015 at 01:39 AM. |
