#21 |
Ring seal is critical. Fixing that will help a lot, and really must happen before you can do much else.
I ran a 87 Firebird 305 carb motor for a while, and they do work well. That was before roller rockers were legal, and I spent a lot of time checking and replacing rocker arms. The 305 was hard on them. The roller rockers should give you some hp and save you a lot of headaches. Use good pushrods too! Bullet and Comp both work well with stocker racers, and either should be able to get you a good, up to date, cam. I have used both in the past. Good luck, and have fun! Ken |
#22 |
Liked 280 Times in 139 Posts
That was the 85? HO carb. motor,that's what they made.They ran real light, would go high 10's in G. gsa612
#23 |
i have contacted cp and looks like it may be a couple weeks waitin on some pistons. whoever recommended cp to me i appreciate that.
And yes cp contacted me on sunday. Marshall is top notch. |
#24 |
Liked 2 Times in 2 Posts
Very Cool!!!
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#25 |
Liked 72 Times in 27 Posts
#26 |
Your gonna like them.
Ed Wright 4156 SS/JA |
#27 |
#28 | |
Liked 49 Times in 15 Posts
But if you are not putting them in a properly prepped Bowtie block or a properly prepped/sleeved 350/307 block, you aren't going to find the power you are looking for. Unless you have a rock solid stable cylinder wall, with the right finish, no piston or ring package will help you. Also consider calling Total Seal for your ring package. If you are used to buying a $50 ring set, then prepare yourself before you call. Good ring packages can be ten times that amount.
Dean Feiock -- Stock 5002 |
#29 |
Liked 1,824 Times in 426 Posts
why CP over everything else? I have them are they that much better than the others?
james perrone 1290 STK |
#30 |
