Amsoil is the best synthetic racing oil on the market today. It was the first and still the best. Its been around since 1972 never had any problems in my motor,trans,or rear using any of there products. If you need anymore imfo i am a dealer contact me.
Rick |
Liked 54 Times in 27 Posts
Diesel oils like Shell Rotella or Chevron Delo 400, both 15-40 weight, have a lot of good additives like ZDDP, if they are the "old" CI4+ spec, and do not also meet CJ. EPA has attacked diesels too, and the traps etc. that they now have do not like those additives. So, the CJ oil is decent but no where near as good as the older CI4+. APE "lets" the oil companies say their new oil is "backwards compatible" so the new stuff like the gold band "low emissions" Delo says CJ and CI4+. My local Chevron distributor still sells the "old" stuff in 5 gallon and larger containers.
Banned
Brad Penn aka KENDELL, good ****.
Liked 858 Times in 234 Posts
No advantage for me using normal synthetics in throttle stop cars, altho I do run a heater to warm the oil to 160 deg before I start the car.
Class cars using ultra light grades yes, some major gains when using oils that have the viscousity of water. Like was said before, I change mine @20 runs ,so its hard to justify the expense of synthetics. I switched to Lucas Racing oil this year ,since it has a very high zinc phosphate content,and the results are excellent ,with no wear problems or lifter issues. PLUS , the contingency award for Div win and r/u is a big plus !
I was having bearing wear issues also and i started using the gm engine oil suppliment (eos) in my oil!!it has zinc along with other anti wear additives and it has solved the issue so far
scott fifield |
Liked 13 Times in 9 Posts
CAM2 Blue Blood Racing Oil has over 2,000PPM Zinc, high phospherous, etc... everything you're looking for, and it's cheaper than some of the other synthetics. I run their 0w30 full synthetic... full time, too, and that includes double-entering at big money bracket races. In my opinion, it's more consistent in hot lap situations, where a 20w50 will start to thin out after so many heat cycles and make the car pick up. They also make some 15w30 and 20w50. cam2racing.com
We run the Lucas 20-50, change every 20-25 passes, and just pulled the engine apart. Bearings and everything else looks great.
Chris Williams 6304 SC, TD, ET |
Rock, Thanks for your comments.
OK, the consensus is to stay with oil that has a zinc compound in it. I switched over to Lucas oil this year as well. I agree that the cost of sythetic does not make it practical for my class. I stayed with the 20/50 grade and the oil pressure would vary from 40-50 psi pre race and 20 psi or so post race. Second question is would a thinner grade oil help. I have expierenced lifter failure twice recently, (80 runs between failures) both on the right bank. 2 & 4 cylinders. It made a mess of a lot of parts. Don't want to go through that again. Thanks, Kevin Tiedemann S/ST145T |
ive had good luck with valvoline vr1, internal looked great.
future superstock eliminator racer and gear banger.... ![]() |
#10 | |
Banned
