#21 |
Think load from car weight could be part of it too?
Ed Wright 4156 SS/JA Last edited by Ed Wright; 02-14-2014 at 08:40 PM. |
#22 |
Yes, just equates back to pressure on the gear face. And what Art mentioned how the gears are cut can affect both how much the gears must actually slide against each other and the actual amount of contact area they have. As for a 1400 hp FWD car using ATF could it be due to necessity as the transmission and differential share the same oil?
Bill Edgeworth 6471 STK |
#23 |
Ed I'm pretty sure the way the gears are cut for a RWD application is the difference. Our ring and pinions make contact in a completely different area.
Art Leong 2095 SS |
#24 | |
Art Leong 2095 SS |
#25 |
Liked 359 Times in 135 Posts
I have a bunch of free Valvoline 75/140 synthetic gear lube that I would like to try. We have a Dana 60 and have had 0 problems in 9 years of hard racing so I'm afraid to change anything. What do you guys think? Just looking for consistency. We now use 80/90 conventional.
Who owns this car, with the peace sign,mag wheels, and four on the floor? |
#26 | |
#27 | |
Liked 1,982 Times in 597 Posts
Mike Pearson 2485 SS |
#28 |
Liked 22 Times in 22 Posts
I don't know if what I do works or not, but it makes me feel good about it. Here goes. I run 1\2 quart synthetic auto trans fluid, 1\2 quart 50 wt. synthetic racing motor oil, and 1 quart synthetic 80\90 gear lube. We put over 100 runs on a 6.20 gear before changing gears. Mostly 1\8th mile. A stick car leaving at 9,200, weighing 3040 lbs. The only thing I see that's changed is we used to get about 150, to 170 runs on a nodular center section then an aluminum through bolt. Anyone ran into that? Makes me wonder if the nodular might actually take less drag because of distortion. I never run it low.
don,t have one |
