#27 |
Liked 251 Times in 125 Posts
Going back together w/ uncut drag springs is a different story, for sure!
I put a set of uncut Eibach drag springs in my 87. I think I used a combination of the compressor and the jack, starting the nut on the balljoint, then lining up the bolt holes in the bushings. It ended up sitting too high. I got greedy and cut 1 1/2 coils off, sat too low. It was a lot easier to get them in, though! I found another set (Both sets were new, unused, bought from guys on The Corral.) and cut 1 coil. The height was good. My car is not an all-out drag car. If it were, I'd be concerned that by cutting the springs, I increased the stiffness too much, reducing the effectiveness of the weight transfer. |
